주요 콘텐츠로 건너뛰기
Disassembling Onkyo TX-800 Face plate
필요한 것
  1. Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 1/3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 2/3 Disassembling Onkyo TX-800 Face plate, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 3/3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Disassembling Onkyo TX-800 Face plate: 2 단계, 이미지 1/2 Disassembling Onkyo TX-800 Face plate: 2 단계, 이미지 2/2
    • Remove the top screw on the back panel.
  3. Disassembling Onkyo TX-800 Face plate: 3 단계, 이미지 1/2 Disassembling Onkyo TX-800 Face plate: 3 단계, 이미지 2/2
    • Slide off the case to expose the internal components of the receiver.
  4. Disassembling Onkyo TX-800 Face plate, Face plate: 4 단계, 이미지 1/3 Disassembling Onkyo TX-800 Face plate, Face plate: 4 단계, 이미지 2/3 Disassembling Onkyo TX-800 Face plate, Face plate: 4 단계, 이미지 3/3
    • Unscrew the three screws on top of the face plate.
  5. Disassembling Onkyo TX-800 Face plate: 5 단계, 이미지 1/2 Disassembling Onkyo TX-800 Face plate: 5 단계, 이미지 2/2
    • Unscrew the one screw on the bottom of the front panel.
  6. Disassembling Onkyo TX-800 Face plate: 6 단계, 이미지 1/3 Disassembling Onkyo TX-800 Face plate: 6 단계, 이미지 2/3 Disassembling Onkyo TX-800 Face plate: 6 단계, 이미지 3/3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ryan
회원 가입일: 04/13/10
108 평판
안내서 3개 작성하였습니다
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G92
4 회원들
안내서 7개 작성하였습니다
댓글 2개
I would like to remove Front Face plate of my Onkyo TX-SR875 AV Receiver. Please guide me how can I open it?
Ashish Solanki - 답글
My Onkyo DX-C370 was “working fine..” until the belts started breaking. Following your disassembly and re-assembly guide, I replaced 3-belts using medium tension O-rings. Drawer opens/closes…, BUT carousel “studders” as it enters the pick-up unit, which does not engage with disk on “PLAY” button depression. I have Service Manual from online source.., and would like to follow “ERROR MESSAGE displays in “Heat-Running Mode” BUTY…, I do not know which panel button corresponds to the “DOWN BUTTON”.., Can You advise on how to get it spinning and playing CDs again..?
Much Thanks, Dom. Mendola, Ph.D. UCSD, Scripps Institution of Oceanography, Retired…
Dominick Mendola - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 24
전체 시간: 3,870
