주요 콘텐츠로 건너뛰기
Disassembling Onkyo TX-800 Logic board
필요한 것
  1. Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 1/3 Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 2/3 Disassembling Onkyo TX-800 Logic board, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 3/3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Disassembling Onkyo TX-800 Logic board: 2 단계, 이미지 1/2 Disassembling Onkyo TX-800 Logic board: 2 단계, 이미지 2/2
    • Remove the top screw on the back panel.
  3. Disassembling Onkyo TX-800 Logic board: 3 단계, 이미지 1/2 Disassembling Onkyo TX-800 Logic board: 3 단계, 이미지 2/2
    • Slide off the case to expose the internal components of the receiver.
  4. Disassembling Onkyo TX-800 Logic board, Face plate: 4 단계, 이미지 1/3 Disassembling Onkyo TX-800 Logic board, Face plate: 4 단계, 이미지 2/3 Disassembling Onkyo TX-800 Logic board, Face plate: 4 단계, 이미지 3/3
    • Unscrew the three screws on top of the face plate.
  5. Disassembling Onkyo TX-800 Logic board: 5 단계, 이미지 1/2 Disassembling Onkyo TX-800 Logic board: 5 단계, 이미지 2/2
    • Unscrew the one screw on the bottom of the front panel.
  6. Disassembling Onkyo TX-800 Logic board: 6 단계, 이미지 1/3 Disassembling Onkyo TX-800 Logic board: 6 단계, 이미지 2/3 Disassembling Onkyo TX-800 Logic board: 6 단계, 이미지 3/3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  7. Disassembling Onkyo TX-800 Logic board, Logic board: 7 단계, 이미지 1/3 Disassembling Onkyo TX-800 Logic board, Logic board: 7 단계, 이미지 2/3 Disassembling Onkyo TX-800 Logic board, Logic board: 7 단계, 이미지 3/3
    • On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
  8. Disassembling Onkyo TX-800 Logic board: 8 단계, 이미지 1/2 Disassembling Onkyo TX-800 Logic board: 8 단계, 이미지 2/2
    • You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ryan
회원 가입일: 04/13/10
108 평판
안내서 3개 작성하였습니다
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G92
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 2,642
