주요 콘텐츠로 건너뛰기
Disassembling Panasonic GU87 Back cover
필요한 것
  1. Disassembling Panasonic GU87 Back cover, Battery: 1 단계, 이미지 1/1
    • Place your hands on the phone as shown in picture. Slightly pull the tab away from the phone with your thumb.
  2. Disassembling Panasonic GU87 Back cover: 2 단계, 이미지 1/1
    • Lift the battery up from the phone as shown. Replace with a new battery if the old battery has become worn out.
  3. Disassembling Panasonic GU87 Back cover, Disassembling Panasonic GU87 Back cover: 3 단계, 이미지 1/1
    • Remove the rubber covers with tweezers.
  4. Disassembling Panasonic GU87 Back cover: 4 단계, 이미지 1/1
    • Remove all 4 screws from the back of the phone.
  5. Disassembling Panasonic GU87 Back cover: 5 단계, 이미지 1/1
    • Use a plastic opening tool to separate the front and back casing.
  6. Disassembling Panasonic GU87 Back cover: 6 단계, 이미지 1/1
    • Put the tool in friction tabs and force down to open the cover as shown in the picture.
    • Carefully pop it open the rest of the way with your fingers.
결론
Van
회원 가입일: 06/24/10
7 평판
안내서 8개 작성하였습니다
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G10
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,177
