주요 콘텐츠로 건너뛰기
Disassembling Panasonic GU87 Minor-LCD
필요한 것
  1. Disassembling Panasonic GU87 Minor-LCD, LCD Cover removal: 1 단계, 이미지 1/1
    • Remove the four rubber screw covers from encircled locations.
    • Using a #0 tri wing screwdriver, remove the screws previously hidden below the rubber covers.
    • If you have difficulties finding this screwdriver, it is commonly sold as a Nintendo Gameboy/Wii screwdriver.
  2. Disassembling Panasonic GU87 Minor-LCD: 2 단계, 이미지 1/1
    • Pry the case open using iPhone tool (as shown), fingernails, small flathead screwdriver, etc.
    • Be mindful of location and magnitude of applied force, so as not to damage the case.
  3. Disassembling Panasonic GU87 Minor-LCD, LCD: 3 단계, 이미지 1/1
    • Unlock the minor LCD connector by applying bilateral pressure with tweezers, as shown.
  4. Disassembling Panasonic GU87 Minor-LCD: 4 단계, 이미지 1/1
    • Use fingernails to pry off minor LCD mount, as shown.
    • Remove the minor LCD
결론
Van
회원 가입일: 06/24/10
7 평판
안내서 8개 작성하였습니다
Cal Poly, Team 2-10, Johann Summer 2010 Cal Poly, Team 2-10, Johann Summer 2010 회원
CPSU-JOHANN-R10S2G10
4 회원들
안내서 20개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,330
