주요 콘텐츠로 건너뛰기
Disassembling Panasonic Lumix DMC-TZ5 Back Cover
필요한 것
  1. Disassembling Panasonic Lumix DMC-TZ5 Back Cover, Back Cover: 1 단계, 이미지 1/1
    • Remove the battery and memory card from the device.
  2. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 2 단계, 이미지 1/1
    • Remove 4 screws from the right side of the camera.
    • There are two 3.4mm screws at the top.
    • There are two 2.2mm screws at the bottom.
  3. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 3 단계, 이미지 1/1
    • Remove the single 3.4mm screw on the left side of the camera.
  4. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 4 단계, 이미지 1/1
    • Remove 5 screws from the base of the camera.
    • There are two 2.2mm screws next to the battery compartment.
    • There are three 4mm screws around the tripod mount.
  5. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 5 단계, 이미지 1/1
    • Slowly slide the back cover away from the device
    • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
  6. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 6 단계, 이미지 1/2 Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 6 단계, 이미지 2/2
    • Detach both ribbon cables using a spudger.
    • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
  7. Disassembling Panasonic Lumix DMC-TZ5 Back Cover: 7 단계, 이미지 1/1
    • Remove the back casing from the camera.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ben Canfield
회원 가입일: 10/10/10
409 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-21, Regan Fall 2010 Cal Poly, Team 9-21, Regan Fall 2010 회원
CPSU-REGAN-F10S9G21
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
That is not a disassembly! All is shows is taking the back of the camera off. How about showing how to disassembly the camera down to its individual components and make repairs, like getting the lens to extend of fixing a sticking shutter.
JR Tan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 21
전체 시간: 6,954
