이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
Use the spudger to disconnect the LCD ribbons.
Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
Unlock lens mechanism located on the bottom of the device using your fingers.
