주요 콘텐츠로 건너뛰기
Philips Marathon Vacuum FC9202 disassembly
필요한 것
  1. Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: 1 단계, 이미지 1/3 Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: 1 단계, 이미지 2/3 Philips Marathon Vacuum FC9202 disassembly, Philips Marathon Vacuum FC9202 disassembly: 1 단계, 이미지 3/3
    • To open the unit, first remove the filter cover, by removing the hinge after removing the end caps
  2. Philips Marathon Vacuum FC9202 disassembly: 2 단계, 이미지 1/1
    • dismantle the handle of the filter cover, removing the Torx screws hidden under the handle
  3. Philips Marathon Vacuum FC9202 disassembly: 3 단계, 이미지 1/3 Philips Marathon Vacuum FC9202 disassembly: 3 단계, 이미지 2/3 Philips Marathon Vacuum FC9202 disassembly: 3 단계, 이미지 3/3
    • the chrome plate can be removed with a screwdriver
    • remove the min/max button and the on/off button; removal of a torx screw
    • electronic card update
  4. Philips Marathon Vacuum FC9202 disassembly: 4 단계, 이미지 1/1
    • To remove the housing, you must remove 7 additional Torx screws
  5. Philips Marathon Vacuum FC9202 disassembly: 5 단계, 이미지 1/2 Philips Marathon Vacuum FC9202 disassembly: 5 단계, 이미지 2/2
    • Rear filter removal
  6. Philips Marathon Vacuum FC9202 disassembly: 6 단계, 이미지 1/1
    • Removal of 4 torx screws
  7. Philips Marathon Vacuum FC9202 disassembly: 7 단계, 이미지 1/1
    • 2 Torx screws under the hinge
  8. Philips Marathon Vacuum FC9202 disassembly: 8 단계, 이미지 1/1
    • 3 screws at the front of the housing
  9. Philips Marathon Vacuum FC9202 disassembly: 9 단계, 이미지 1/1
    • housing removal
결론
다른 6명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
christophe
회원 가입일: 07/14/12
806 평판
안내서 2개 작성하였습니다
댓글 7개
Merci pour les infos.
Doc red and yellow - 답글
hallo
bei mir sind die raeder abgefallen,wissen sie wie man die wieder anbringt?
mfg
vural oral - 답글
Bis hierher super erklärt und bebildert. Aber, ich muss an den Motor. Sollte man aber auch schaffen. Wenn er soweit zerlegt ist dürfte das auch kein Problem sein. Gut gemacht
Peter Loehr - 답글
Hallo,
kann mir jemand die Bezeichnung von dem Triac nenne?
MfG
M.Classen
mat - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 29
30일 전: 150
전체 시간: 12,127
