주요 콘텐츠로 건너뛰기
Disassembling Philips Portable Speaker SBA1610 37 Battery Casing
필요한 것
  1. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing, Battery Casing: 1 단계, 이미지 1/1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 2 단계, 이미지 1/3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 2 단계, 이미지 2/3 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 2 단계, 이미지 3/3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 3 단계, 이미지 1/2 Disassembling Philips Portable Speaker SBA1610 37 Battery Casing: 3 단계, 이미지 2/2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Neal
회원 가입일: 10/18/13
152 평판
안내서 1개 작성함
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 회원
CLEM-BENSON-F13S14G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 18
전체 시간: 4,715
