주요 콘텐츠로 건너뛰기
소개
The X9 requires removing the exhaust for oil changes, rear brake pad or rotor replacement, and rear tire replacement.
부품
지정된 부품이 없습니다.
  1. Loosen the exhaust strap: Use an 12mm wrench to loosen the exhaust band lock nut.
    • Loosen the exhaust strap:
    • Use an 12mm wrench to loosen the exhaust band lock nut.
    • A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
    • The Allen bolt is screwed into a loose nut in a cavity cast into the swing arm. It may fall out or become twisted. A magnet is helpful in retrieving it to re-align it for reassembly.
    • Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
  2. Use a 13mm socket to loosen the clamp between the muffler and header pipe.
    • Use a 13mm socket to loosen the clamp between the muffler and header pipe.
    • You do not need to remove the bolt, but you want to loosen the clamp enough to allow the exhaust to be removed without damaging the gasket between the muffler and header pipe.
  3. A Torx T40 driver is required to remove the final bolt securing the exhaust.
    • A Torx T40 driver is required to remove the final bolt securing the exhaust.
    • The Exhaust assembly is now free. Pull and wiggle the muffler back (taking care not to damage your exhaust joint gasket) until the muffler comes free from the header pipe.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eric Essen
회원 가입일: 2010년 06월 04일
17,025 평판
안내서 8개 작성하였습니다
iFixit iFixit 회원
Community
137 회원들
안내서 16,049개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 4,121
