소개
The X9 requires removing the exhaust for oil changes, rear brake pad or rotor replacement, and rear tire replacement.
필요한 것
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
다른 2명이 해당 안내서를 완성하였습니다.
