주요 콘텐츠로 건너뛰기
Disassembling Planet Eclipse Etha Frame
필요한 것
  1. Disassembling Planet Eclipse Etha Frame, Regulator: 1 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame, Regulator: 1 단계, 이미지 2/2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Disassembling Planet Eclipse Etha Frame: 2 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame: 2 단계, 이미지 2/2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 3 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame, Battery and Grip Panels: 3 단계, 이미지 2/2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Disassembling Planet Eclipse Etha Frame: 4 단계, 이미지 1/1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Disassembling Planet Eclipse Etha Frame: 5 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame: 5 단계, 이미지 2/2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Disassembling Planet Eclipse Etha Frame, Frame: 6 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame, Frame: 6 단계, 이미지 2/2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Disassembling Planet Eclipse Etha Frame: 7 단계, 이미지 1/2 Disassembling Planet Eclipse Etha Frame: 7 단계, 이미지 2/2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Disassembling Planet Eclipse Etha Frame: 8 단계, 이미지 1/1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
결론
nicholasj6
회원 가입일: 10/14/14
261 평판
안내서 2개 작성하였습니다
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G42
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 375
