주요 콘텐츠로 건너뛰기
Disassembling Planet Eclipse Geo3 Body
필요한 것
  1. Disassembling Planet Eclipse Geo3 Body, Grip: 1 단계, 이미지 1/2 Disassembling Planet Eclipse Geo3 Body, Grip: 1 단계, 이미지 2/2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Disassembling Planet Eclipse Geo3 Body: 2 단계, 이미지 1/2 Disassembling Planet Eclipse Geo3 Body: 2 단계, 이미지 2/2
    • Pull the grip away from the frame.
  3. Disassembling Planet Eclipse Geo3 Body: 3 단계, 이미지 1/2 Disassembling Planet Eclipse Geo3 Body: 3 단계, 이미지 2/2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Disassembling Planet Eclipse Geo3 Body, Macroline: 4 단계, 이미지 1/3 Disassembling Planet Eclipse Geo3 Body, Macroline: 4 단계, 이미지 2/3 Disassembling Planet Eclipse Geo3 Body, Macroline: 4 단계, 이미지 3/3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Disassembling Planet Eclipse Geo3 Body: 5 단계, 이미지 1/3 Disassembling Planet Eclipse Geo3 Body: 5 단계, 이미지 2/3 Disassembling Planet Eclipse Geo3 Body: 5 단계, 이미지 3/3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Disassembling Planet Eclipse Geo3 Body, Body: 6 단계, 이미지 1/3 Disassembling Planet Eclipse Geo3 Body, Body: 6 단계, 이미지 2/3 Disassembling Planet Eclipse Geo3 Body, Body: 6 단계, 이미지 3/3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Disassembling Planet Eclipse Geo3 Body: 7 단계, 이미지 1/3 Disassembling Planet Eclipse Geo3 Body: 7 단계, 이미지 2/3 Disassembling Planet Eclipse Geo3 Body: 7 단계, 이미지 3/3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
결론
Rett Triplett
회원 가입일: 10/18/13
801 평판
안내서 8개 작성하였습니다
Clemson, Team 13-6, Benson Fall 2013 Clemson, Team 13-6, Benson Fall 2013 회원
CLEM-BENSON-F13S13G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 584
