주요 콘텐츠로 건너뛰기
Disassembling PlayStation 2 Slimline Outer Shell
필요한 것
  1. Disassembling PlayStation 2 Slimline Outer Shell, Outer Shell: 1 단계, 이미지 1개 중 1개
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. Disassembling PlayStation 2 Slimline Outer Shell: 2 단계, 이미지 3개 중 1개 Disassembling PlayStation 2 Slimline Outer Shell: 2 단계, 이미지 3개 중 2개 Disassembling PlayStation 2 Slimline Outer Shell: 2 단계, 이미지 3개 중 3개
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. Disassembling PlayStation 2 Slimline Outer Shell: 3 단계, 이미지 3개 중 1개 Disassembling PlayStation 2 Slimline Outer Shell: 3 단계, 이미지 3개 중 2개 Disassembling PlayStation 2 Slimline Outer Shell: 3 단계, 이미지 3개 중 3개
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. Disassembling PlayStation 2 Slimline Outer Shell: 4 단계, 이미지 3개 중 1개 Disassembling PlayStation 2 Slimline Outer Shell: 4 단계, 이미지 3개 중 2개 Disassembling PlayStation 2 Slimline Outer Shell: 4 단계, 이미지 3개 중 3개
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
결론
다른 20명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Thomas Sullivan
회원 가입일: 10/23/13
4,423 평판
안내서 6개를 작성함
3가이드 댓글
Just to clarify: in order to FULLY remove the bottom half of the shell on my PS2 Slim, I had to remove a screw that pinned the controller ports in place; it's at the front, right between the Player 1 and Player 2 ports.
Other than that, this guide worked perfectly! :D
Kizul Emeraldfire - 답글
Good morning. Hello. The disassembly of the PS2 series 7XXXX (PS2 Slim) is very well explained, except for one detail. Indeed, when I started to separate the bottom from the top, a small metal plate with a threaded hole in the center. And I find no mention of it anywhere. Considering the part, I think it's used by one of the screws that holds the two plastic hulls, but I don't see where. Can you help me, please? Friendly, Marc.
Translated with www.DeepL.com/Translator
Marc Blériot - 답글
The metal plate with a screw hole in the middle is for the stand-up-base-stand to be screwed down. It’s an after market item SONY sold seperately.
김동현 -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 30
지난 30일: 142
전체 시간: 14,018
