주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
필요한 것
동영상 개요
  1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 1 단계, 이미지 2개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: 1 단계, 이미지 2개 중 2개
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
    댓글 쓰기
  2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 2 단계, 이미지 3개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 2 단계, 이미지 3개 중 2개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 2 단계, 이미지 3개 중 3개
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
    댓글 쓰기
  3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 3 단계, 이미지 2개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 3 단계, 이미지 2개 중 2개
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
    댓글 쓰기
  4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 4 단계, 이미지 3개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 4 단계, 이미지 3개 중 2개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 4 단계, 이미지 3개 중 3개
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
    댓글 쓰기
  5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 5 단계, 이미지 2개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 5 단계, 이미지 2개 중 2개
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    댓글 쓰기
  6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 6 단계, 이미지 1개 중 1개
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
    댓글 쓰기
  7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 7 단계, 이미지 1개 중 1개
    • Free the battery cable by gently prying up on the connection with a spudger.
    댓글 쓰기
  8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 8 단계, 이미지 1개 중 1개
    • Separate the front and rear cases.
    댓글 쓰기
  9. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 9 단계, 이미지 2개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: 9 단계, 이미지 2개 중 2개
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
    댓글 쓰기
  10. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 10 단계, 이미지 2개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 10 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
    댓글 쓰기
  11. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 11 단계, 이미지 3개 중 1개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 11 단계, 이미지 3개 중 2개 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): 11 단계, 이미지 3개 중 3개
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
djgodmandj
회원 가입일: 10/24/14
302 평판
안내서 1개를 작성함
1가이드 댓글
So is there any chance that this could be used as a modding possibility, where we could install a higher resolution /quality screen?
TheHeavy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 56
지난 30일: 236
전체 시간: 10,033
