주요 콘텐츠로 건너뛰기
Disassembling Polaroid a520 Lens
필요한 것
  1. Disassembling Polaroid a520 Lens, Battery: 1 단계, 이미지 2개 중 1개 Disassembling Polaroid a520 Lens, Battery: 1 단계, 이미지 2개 중 2개
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Lens: 2 단계, 이미지 1개 중 1개
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Lens, Casing: 3 단계, 이미지 1개 중 1개
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Lens: 4 단계, 이미지 1개 중 1개
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Lens, LCD Screen: 5 단계, 이미지 1개 중 1개
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Lens: 6 단계, 이미지 1개 중 1개
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Lens, Logic Board: 7 단계, 이미지 1개 중 1개
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  8. Disassembling Polaroid a520 Lens: 8 단계, 이미지 1개 중 1개
    • Pull the inner casing off of the camera.
  9. Disassembling Polaroid a520 Lens: 9 단계, 이미지 1개 중 1개
    • Unscrew and remove the four (4mm) screws from the logic board.
  10. Disassembling Polaroid a520 Lens: 10 단계, 이미지 1개 중 1개
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
  11. Disassembling Polaroid a520 Lens, Lens: 11 단계, 이미지 1개 중 1개
    • Unscrew and remove the two (5mm) screws from the logic board to the far left.
  12. Disassembling Polaroid a520 Lens: 12 단계, 이미지 1개 중 1개
    • Locate the black plastic piece behind the lens.
  13. Disassembling Polaroid a520 Lens: 13 단계, 이미지 1개 중 1개
    • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
    • The piece will not come all the way off; only enough to release the lens.
    • Once the black piece is lifted slide the ribbon out to release the lens.
결론
작성자
3다른 기여자 명과 함께
Dani
회원 가입일: 06/24/10
21 평판
안내서 7개를 작성함
Cal Poly, Team 3-3, Johann Summer 2010 Cal Poly, Team 3-3, Johann Summer 2010 회원
CPSU-JOHANN-R10S3G3
2 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 1,218
