주요 콘텐츠로 건너뛰기
Disassembling Qualcomm QCP-2760 Rear Backing
필요한 것
  1. Disassembling Qualcomm QCP-2760 Rear Backing, Battery: 1 단계, 이미지 1/1
    • Unscrew the back battery plate from the phone using a T6 Torx screwdriver.
    • The screw does not need to be removed completely, the back battery plate will unhinge from the phone.
  2. Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: 2 단계, 이미지 1/2 Disassembling Qualcomm QCP-2760 Rear Backing, Rear Backing: 2 단계, 이미지 2/2
    • Using the T6 Torx screwdriver, remove the two screws located at the bottom of the back of the phone.
    • Find the seam between the front and back of the phone
    • Pry the seam open using a plastic opening tool, or your fingers.
    • Some force is required
결론
Xavier
회원 가입일: 10/02/14
313 평판
안내서 3개 작성하였습니다
Ohio State, Team 1-4, Buehl Fall 2014 Ohio State, Team 1-4, Buehl Fall 2014 회원
OSU-BUEHL-F14S1G4
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 210
