주요 콘텐츠로 건너뛰기
Disassembling Quasar Microwave Outer Cover
필요한 것
  1. Disassembling Quasar Microwave Outer Cover, Disassembling Quasar Microwave Outer Cover: 1 단계, 이미지 1/1
    • Disconnect the power supply cord from the outlet.
  2. Disassembling Quasar Microwave Outer Cover: 2 단계, 이미지 1/2 Disassembling Quasar Microwave Outer Cover: 2 단계, 이미지 2/2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. Disassembling Quasar Microwave Outer Cover: 3 단계, 이미지 1/2 Disassembling Quasar Microwave Outer Cover: 3 단계, 이미지 2/2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  4. Disassembling Quasar Microwave Outer Cover: 4 단계, 이미지 1/3 Disassembling Quasar Microwave Outer Cover: 4 단계, 이미지 2/3 Disassembling Quasar Microwave Outer Cover: 4 단계, 이미지 3/3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Samuel
회원 가입일: 09/26/12
142 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-12, Propen Fall 2012 Cal Poly, Team 2-12, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G12
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 26
전체 시간: 2,533
