주요 콘텐츠로 건너뛰기
Disassembling RCA 22” DECK215R HDTV Stand and Back Panel
필요한 것
  1. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Stand: 1 단계, 이미지 1/2 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Stand: 1 단계, 이미지 2/2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Back Panel: 2 단계, 이미지 1/2 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Back Panel: 2 단계, 이미지 2/2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Locate Pin: 3 단계, 이미지 1/1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: 4 단계, 이미지 1/3 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: 4 단계, 이미지 2/3 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: 4 단계, 이미지 3/3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Patrick Soper
회원 가입일: 01/15/15
691 평판
안내서 6개 작성하였습니다
Cal Poly, Team 70-2, Forte Winter 2015 Cal Poly, Team 70-2, Forte Winter 2015 회원
CPSU-FORTE-W15S70G2
4 회원들
안내서 10개 작성하였습니다
댓글 8개
essay about social media will be also interesting for you. In case if you like reading interesting short topics on different themes, you are welcomed to read or articles.
Cortez Baylor - 답글
Livin' in a world where no one's innocent Oh, but at least we try, mmm Gotta live my truth, not keep it bottled in So I don't lose my mind, baby, yeah
geometry dash
pkinpum - 답글
I've been utilizing essay writing services from essayreasures.com for four months now. Recommend them!
Tommy - 답글
Dude. Awesome vid! Thank you so much for this, you saved my tookus. I have the Trio Stealth G2 and the guts look EXACTLY the same as the RCA in your vid. Actually I have 2 and one of them (the one with the messed up power button, just like yours) is being used now for parts.Just swapped out the guts on the one with the cracked screen with the one with the bad power button. Only difference was they had glued the battery in instead of adhesive strips. Thanks again, you rock. Stickman Hook
Rose Watson - 답글
Are you a lover of finding and discovering new words?
If that's the case, then this Word Finder is a tool you just can't do without.
Anna Stark - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 1,982
