소개
The stand and back panel removal are the first steps to fixing anything in your TV.
필요한 것
Lay the TV flat with the screen facing down.
Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
Remove the stand by lifting it away from the TV's backing.
Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
Position the television to where the back panel is resting on the table and the screen is vertical.
Peel the tape covering the ribbon cable horizontally.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 8개
essay about social media will be also interesting for you. In case if you like reading interesting short topics on different themes, you are welcomed to read or articles.
Livin' in a world where no one's innocent Oh, but at least we try, mmm Gotta live my truth, not keep it bottled in So I don't lose my mind, baby, yeah
I've been utilizing essay writing services from essayreasures.com for four months now. Recommend them!
Dude. Awesome vid! Thank you so much for this, you saved my tookus. I have the Trio Stealth G2 and the guts look EXACTLY the same as the RCA in your vid. Actually I have 2 and one of them (the one with the messed up power button, just like yours) is being used now for parts.Just swapped out the guts on the one with the cracked screen with the one with the bad power button. Only difference was they had glued the battery in instead of adhesive strips. Thanks again, you rock. Stickman Hook
Are you a lover of finding and discovering new words?
If that's the case, then this Word Finder is a tool you just can't do without.
Anna Stark - 답글
You are a football enthusiast. If so then you should try our game . Retro bowl is a nostalgic American football. You will play the role of the manager in charge of signing contracts, cutting players.
Wish you happy gaming.
Anna Stark - 답글
too mnay screws to disassembling, i defenately needs a moterized screw driver...haha anyway nice post.. https://vintagewatches.pk
Перед разборкой телевизора убедитесь, что все кабели отсоединены от источника питания, чтобы избежать серьезных травм или смерти от поражения электрическим током slope unblocked.
Hugh Walsh - 답글
Do you like playing game? What kind of games do you usually play? If you want to find a new game that is still very familiar, try play solitaire.
Lisa Sarah - 답글
