주요 콘텐츠로 건너뛰기
Disassembling Razer Basilisk X Hyperspeed Top Case
필요한 것
    • First heat up the underside of the device, so the glue of the stickers softens up.
  1. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: 2 단계, 이미지 3개 중 1개 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: 2 단계, 이미지 3개 중 2개 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: 2 단계, 이미지 3개 중 3개
    • Use the tweezers to lift the bottom slider, if you use your nails you might just lift the slider, instead of all the glue with the slider.
  2. Disassembling Razer Basilisk X Hyperspeed Top Case, Unscrew: 3 단계, 이미지 1개 중 1개
    • Remove all 4 screws.
    • There is 1 at the bottom under the slider.
    • The top ones are under the letter A from BASILISK and the other one between the EE from HYPERSPEED.
    • The last one is on top of the last 4 digits of the IFETEL number.
  3. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: 4 단계, 이미지 2개 중 1개 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: 4 단계, 이미지 2개 중 2개
    • First remove battery, after that, lift it from the bottom using your nail or a prying tool from the gap at the bottom. Open it carefully, since there are wire connectors. Carefully disconnect from the plastic to avoid damage, DO NOT PULL FROM THE WIRES.
  4. Disassembling Razer Basilisk X Hyperspeed Top Case, Admire your work: 5 단계, 이미지 1개 중 1개
    • If you need to remove the board, you need a 00 Philips bit for the screws on the board and a 1 Philips bit for the screws on the side buttons, other than that, you have full access to the board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Toaster Roaster
회원 가입일: 04/14/23
707 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 15
지난 7일: 104
지난 30일: 409
전체 시간: 6,124
