주요 콘텐츠로 건너뛰기
Disassembling Samsung Galaxy Ace Logic Board
필요한 것
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: 1 단계, 이미지 1/2 Disassembling Samsung Galaxy Ace Logic Board, Logic Board: 1 단계, 이미지 2/2
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: 2 단계, 이미지 1/2 Disassembling Samsung Galaxy Ace Logic Board: 2 단계, 이미지 2/2
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: 3 단계, 이미지 1/3 Disassembling Samsung Galaxy Ace Logic Board: 3 단계, 이미지 2/3 Disassembling Samsung Galaxy Ace Logic Board: 3 단계, 이미지 3/3
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: 4 단계, 이미지 1/2 Disassembling Samsung Galaxy Ace Logic Board: 4 단계, 이미지 2/2
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: 5 단계, 이미지 1/3 Disassembling Samsung Galaxy Ace Logic Board: 5 단계, 이미지 2/3 Disassembling Samsung Galaxy Ace Logic Board: 5 단계, 이미지 3/3
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: 6 단계, 이미지 1/1
    • Lift the microphone from the logic board.
    How can you replace the microphone?
    Henna - 답글
  7. Disassembling Samsung Galaxy Ace Logic Board: 7 단계, 이미지 1/3 Disassembling Samsung Galaxy Ace Logic Board: 7 단계, 이미지 2/3 Disassembling Samsung Galaxy Ace Logic Board: 7 단계, 이미지 3/3
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: 8 단계, 이미지 1/3 Disassembling Samsung Galaxy Ace Logic Board: 8 단계, 이미지 2/3 Disassembling Samsung Galaxy Ace Logic Board: 8 단계, 이미지 3/3
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: 9 단계, 이미지 1/2 Disassembling Samsung Galaxy Ace Logic Board: 9 단계, 이미지 2/2
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: 10 단계, 이미지 1/3 Disassembling Samsung Galaxy Ace Logic Board: 10 단계, 이미지 2/3 Disassembling Samsung Galaxy Ace Logic Board: 10 단계, 이미지 3/3
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: 11 단계, 이미지 1/1
    • Now you can work with the Logic board.
결론
다른 34명이 해당 안내서를 완성하였습니다.
finster
회원 가입일: 08/17/11
1,986 평판
안내서 1개 작성함
댓글 2개
Thanks for the post. This is really Helpful
Dave Dayanan - 답글
im curently selling one thx to you
Kyle at work - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 26,698
