주요 콘텐츠로 건너뛰기
Disassembling Samsung Galaxy S Blaze Whole Device
필요한 것
  1. Disassembling Samsung Galaxy S Blaze Whole Device, Disassembling Samsung Galaxy S Blaze Whole Device: 1 단계, 이미지 1/1
    • Remove the back plate.
  2. Disassembling Samsung Galaxy S Blaze Whole Device: 2 단계, 이미지 1/1
    • Remove the battery from the device.
  3. Disassembling Samsung Galaxy S Blaze Whole Device: 3 단계, 이미지 1/2 Disassembling Samsung Galaxy S Blaze Whole Device: 3 단계, 이미지 2/2
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Disassembling Samsung Galaxy S Blaze Whole Device: 4 단계, 이미지 1/1
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Disassembling Samsung Galaxy S Blaze Whole Device: 5 단계, 이미지 1/1
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  6. Disassembling Samsung Galaxy S Blaze Whole Device: 6 단계, 이미지 1/1
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  7. Disassembling Samsung Galaxy S Blaze Whole Device: 7 단계, 이미지 1/1
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  8. Disassembling Samsung Galaxy S Blaze Whole Device: 8 단계, 이미지 1/3 Disassembling Samsung Galaxy S Blaze Whole Device: 8 단계, 이미지 2/3 Disassembling Samsung Galaxy S Blaze Whole Device: 8 단계, 이미지 3/3
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  9. Disassembling Samsung Galaxy S Blaze Whole Device: 9 단계, 이미지 1/1
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  10. Disassembling Samsung Galaxy S Blaze Whole Device: 10 단계, 이미지 1/1
    • All of the parts are seen here.
결론
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
다른 2명이 해당 안내서를 완성하였습니다.
Jake Best
회원 가입일: 03/05/15
261 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 11-1, Blackburne Winter 2015 Sam Houston State, Team 11-1, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S11G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 736
