주요 콘텐츠로 건너뛰기
Disassembling Samsung Gear 2 Front half and Back half
필요한 것
  1. Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: 1 단계, 이미지 2개 중 1개 Disassembling Samsung Gear 2 Front half and Back half, Front half and Back half: 1 단계, 이미지 2개 중 2개
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Disassembling Samsung Gear 2 Front half and Back half: 2 단계, 이미지 1개 중 1개
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Disassembling Samsung Gear 2 Front half and Back half: 3 단계, 이미지 3개 중 1개 Disassembling Samsung Gear 2 Front half and Back half: 3 단계, 이미지 3개 중 2개 Disassembling Samsung Gear 2 Front half and Back half: 3 단계, 이미지 3개 중 3개
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Jonathan Molina
회원 가입일: 04/14/14
1,018 평판
안내서 2개를 작성함
Cal Poly, Team 13-27, Maness Spring 2014 Cal Poly, Team 13-27, Maness Spring 2014 회원
CPSU-MANESS-S14S13G27
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 3,329
