주요 콘텐츠로 건너뛰기
Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera
필요한 것
  1. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Disassembling Samsung Gravity SGH-T459  Back Cover: 1 단계, 이미지 1/1
    • Press and hold the End key to power down the cell phone.
    • Gently remove the back cover with your fingers by sliding it in the direction of the arrows.
  2. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Disassembling Samsung Gravity SGH-T459  Battery: 2 단계, 이미지 1/1
    • Gently lift up and remove battery with your fingers in the direction of the arrows.
  3. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: 3 단계, 이미지 1/3 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: 3 단계, 이미지 2/3 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, Rear Case: 3 단계, 이미지 3/3
    • Hold the cell phone steady with one hand. With the other hand, use a Phillips screwdriver to remove all 6 screws around the edges of the rear case.
    • Slide the phone open.
    • Use a plastic prying tool to pry open the edge of the green trim near the space bar of the keypad. You should hear the rear case unsnap.
    • Gently lift and remove the rear case from the cell phone.
  4. Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, 1.3 megapixel camera: 4 단계, 이미지 1/2 Disassembling Samsung Gravity SGH-T459 1.3 megapixel camera, 1.3 megapixel camera: 4 단계, 이미지 2/2
    • Gently lift and remove the 1.3 megapixel camera with your fingers.
결론
William Glatz
회원 가입일: 03/11/13
1 평판
안내서 5개 작성하였습니다
University of Maryland, Team 1-1, Calloway Spring 2013 University of Maryland, Team 1-1, Calloway Spring 2013 회원
UMD-CALLOWAY-S13S1G1
1 회원
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 642
