주요 콘텐츠로 건너뛰기
Disassembling Samsung TFT Color YP-T7J Removing the Front Cover
필요한 것
  1. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: 1 단계, 이미지 1/2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Back Cover: 1 단계, 이미지 2/2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 2 단계, 이미지 1/2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 2 단계, 이미지 2/2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 3 단계, 이미지 1/3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 3 단계, 이미지 2/3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 3 단계, 이미지 3/3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: 4 단계, 이미지 1/2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover, The Front Cover: 4 단계, 이미지 2/2
    • Using the philips screwdriver, remove the two screws on the mother board.
  5. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 5 단계, 이미지 1/3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 5 단계, 이미지 2/3 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 5 단계, 이미지 3/3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  6. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 6 단계, 이미지 1/1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  7. Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 7 단계, 이미지 1/2 Disassembling Samsung TFT Color YP-T7J Removing the Front Cover: 7 단계, 이미지 2/2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jason Farr
회원 가입일: 10/21/13
353 평판
안내서 3개 작성하였습니다
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013 회원
CLEM-BENSON-F13S14G8
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 242
