필요한 것
Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
Remove battery. The battery is taped down with a little double sided tape
If you are replacing the battery just apply a soldering iron to the battery connections on the board and gently pull them off..
To re-attached the new battery by reheating the old solder and reconnecting the new battery wires
Link to a battery Battery Clerk - Sansa Fuze battery
PLEASE NOT IF REPLACING THE BATTERY YOU DO NOT NEED TO REMOVE THE BOARD :)
다른 8명이 해당 안내서를 완성하였습니다.
댓글 6개
Sep 7 is backwards - device power button is on the right side, release motherboard on that side first. Otherwise thank you for the guide!
