필요한 것
Pry open and pop the clips. Note that the bottom two clips are held in with a little bit of rubbery glue. Don’t rip the face off too quick since there is a ribbon cable you need to disconnect.
Remove ribbon cable connect to the face plate. Lift the face off and flip the brown ribbon release flap on the connection on the board. (The flap in this picture is black, opposite the cable. Lift the edge that is closest to you in the picture in order to release the cable.)
I still cant remove the ribbon part am i supposed to lift the black part up or the white one
Remove battery. The battery is taped down with a little double sided tape
If you are replacing the battery just apply a soldering iron to the battery connections on the board and gently pull them off..
To re-attached the new battery by reheating the old solder and reconnecting the new battery wires
Link to a battery Battery Clerk - Sansa Fuze battery
PLEASE NOT IF REPLACING THE BATTERY YOU DO NOT NEED TO REMOVE THE BOARD :)
Replacement batteries may come with a large sticker with branding and warnings on that may make them too bulky to fit, peel this off and it should fit.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 6개
Sep 7 is backwards - device power button is on the right side, release motherboard on that side first. Otherwise thank you for the guide!
Just completed this guide to replace a tired battery, added some notes. The case doesn't clip back together too well due to the broken clips, but I have a leather case it fits in, which holds it together adequately.
The clips are square loops protruding front the front clear polycarbonate, and are quite brittle, they are prone to breaking
Giles Phillips - 답글
