주요 콘텐츠로 건너뛰기
Disassembling Sanyo Katana Eclipse X's Back Panel
필요한 것
  1. Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: 1 단계, 이미지 1/2 Disassembling Sanyo Katana Eclipse X's Back Panel, Back Panel: 1 단계, 이미지 2/2
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X's Back Panel: 2 단계, 이미지 1/1
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
결론
Thomas Scaggs
회원 가입일: 10/15/12
209 평판
안내서 2개 작성하였습니다
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G3
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 13
전체 시간: 300
