소개
This guide illustrates how to remove the battery from a Sanyo Katana Eclipse X.
부품
부품은 필요하지 않습니다.
  1. Press the battery release button located on the back of the phone. With the button depressed, pull down on the battery protector to remove it from the phone.
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
      • The phone's battery will now be exposed.
  2. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
      • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
결론
Thomas Scaggs
회원 가입일: 2012년 10월 15일
209 평판
안내서 2개 작성하였습니다
University of Maine, Team 1-3, Diaz Fall 2012 University of Maine, Team 1-3, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G3
5 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 169
