주요 콘텐츠로 건너뛰기
Disassembling Sanyo SCP-8100 Back Panel
필요한 것
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: 1 단계, 이미지 1/3 Disassembling Sanyo SCP-8100 Back Panel, Battery: 1 단계, 이미지 2/3 Disassembling Sanyo SCP-8100 Back Panel, Battery: 1 단계, 이미지 3/3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: 2 단계, 이미지 1/2 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: 2 단계, 이미지 2/2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: 3 단계, 이미지 1/1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: 4 단계, 이미지 1/2 Disassembling Sanyo SCP-8100 Back Panel: 4 단계, 이미지 2/2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: 5 단계, 이미지 1/3 Disassembling Sanyo SCP-8100 Back Panel: 5 단계, 이미지 2/3 Disassembling Sanyo SCP-8100 Back Panel: 5 단계, 이미지 3/3
    • While removing the back panel, take out the rubber cover on each side.
결론
Yemane
회원 가입일: 04/13/13
11 평판
안내서 1개 작성함
Cal Poly, Team 10-41, Amido Spring 2013 Cal Poly, Team 10-41, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G41
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 382
