주요 콘텐츠로 건너뛰기
Disassembling Sanyo VPC-T850 Outer Casing
필요한 것
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: 1 단계, 이미지 1/1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: 2 단계, 이미지 1/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: 2 단계, 이미지 2/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: 2 단계, 이미지 3/3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: 3 단계, 이미지 1/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: 3 단계, 이미지 2/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: 3 단계, 이미지 3/3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: 4 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: 5 단계, 이미지 1/1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: 6 단계, 이미지 1/2 Disassembling Sanyo VPC-T850 Outer Casing: 6 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: 7 단계, 이미지 1/2 Disassembling Sanyo VPC-T850 Outer Casing: 7 단계, 이미지 2/2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: 8 단계, 이미지 1/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: 8 단계, 이미지 2/3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: 8 단계, 이미지 3/3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
결론
Jonathan Yau
회원 가입일: 04/11/10
26 평판
안내서 4개 작성하였습니다
Cal Poly, Team 27-95, Amido Spring 2010 Cal Poly, Team 27-95, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G95
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 2,036
