주요 콘텐츠로 건너뛰기
Disassembling Siemens A56 Motherboard Metal Frame
필요한 것
  1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 1 단계, 이미지 1/3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 1 단계, 이미지 2/3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 1 단계, 이미지 3/3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 2 단계, 이미지 1/3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 2 단계, 이미지 2/3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 2 단계, 이미지 3/3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  3. Disassembling Siemens A56 Motherboard Metal Frame: 3 단계, 이미지 1/3 Disassembling Siemens A56 Motherboard Metal Frame: 3 단계, 이미지 2/3 Disassembling Siemens A56 Motherboard Metal Frame: 3 단계, 이미지 3/3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  4. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 4 단계, 이미지 1/3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 4 단계, 이미지 2/3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 4 단계, 이미지 3/3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
결론
Joseph Casey
회원 가입일: 03/26/14
409 평판
안내서 4개 작성하였습니다
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 회원
CLEM-BENSON-S14S6G6
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 180
