주요 콘텐츠로 건너뛰기
Disassembling Sirius Stiletto 100 Circuit Board
필요한 것
  1. Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 1 단계, 이미지 1/2 Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 1 단계, 이미지 2/2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Circuit Board: 2 단계, 이미지 1/2 Disassembling Sirius Stiletto 100 Circuit Board: 2 단계, 이미지 2/2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Circuit Board: 3 단계, 이미지 1/3 Disassembling Sirius Stiletto 100 Circuit Board: 3 단계, 이미지 2/3 Disassembling Sirius Stiletto 100 Circuit Board: 3 단계, 이미지 3/3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Circuit Board, Circuit Board: 4 단계, 이미지 1/1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Circuit Board: 5 단계, 이미지 1/2 Disassembling Sirius Stiletto 100 Circuit Board: 5 단계, 이미지 2/2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Circuit Board: 6 단계, 이미지 1/1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Staten
회원 가입일: 03/09/12
69 평판
안내서 1개 작성함
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 회원
CLEM-BENSON-S12S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,915
