필요한 것
Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
Remove the front cover.
First, insert a small pry bar where the black front cover and white back cover meet.
Begin prying the black plastic up, slowing moving around to the bottom and other side.
At an angle, carefully pull up on the front cover separate the two pieces.
Excellent! Now you have removed the front cover!
While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
Flip the circuit board over to look at the back side, so that LCD screen is facing away from you.
Use a Phillip's head screwdriver to remove the screw from the back of the internal antenna.
다른 한 분이 해당 안내서를 완성하였습니다.
