소개
You will take apart the camera case to access the circuit board after removing the battery. Be ready to handle small parts and screws.
필요한 것
Open the bottom tab with your finger or a plastic opening tool.
Pull the tab out, not up, to remove it completely.
Remove the two screws from the device.
Use your fingers to remove the plastic plate.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
