주요 콘텐츠로 건너뛰기
Disassembling Sony Action Cam HDR-AS15 Circuit Board
필요한 것
  1. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Battery: 1 단계, 이미지 1/1
    • To access the battery, gently pry open the rear cover of the action cam.
  2. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 2 단계, 이미지 1/2 Disassembling Sony Action Cam HDR-AS15 Circuit Board: 2 단계, 이미지 2/2
    • Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
  3. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 3 단계, 이미지 1/3 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 3 단계, 이미지 2/3 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 3 단계, 이미지 3/3
    • Open the bottom tab with your finger or a plastic opening tool.
    • Pull the tab out, not up, to remove it completely.
    • Remove the two screws from the device.
    • Use your fingers to remove the plastic plate.
  4. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 4 단계, 이미지 1/1
    • Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
  5. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 5 단계, 이미지 1/2 Disassembling Sony Action Cam HDR-AS15 Circuit Board: 5 단계, 이미지 2/2
    • Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
    • Flip the LCD display downward to reveal the circuit board.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Scott Scarpinato
회원 가입일: 01/06/15
185 평판
안내서 1개 작성함
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G2
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,620
