주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  3. Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  4. Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver. Remove the back panel by lifting it away with your hands.
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
결론
Daniel Soski
회원 가입일: 2013년 04월 18일
20 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 회원
CPSU-MANESS-S13S14G11
5 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 351
