메인 콘텐츠로 스킵하기
소개
Make sure you have the necessary tools in order to complete the disassembly for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
  1. Begin by removing all six #00 screws holding the outer chassis together. Remember to keep track of all screws as they are small and very easy to lose Remember to keep track of all screws as they are small and very easy to lose
    • Begin by removing all six #00 screws holding the outer chassis together.
    • Remember to keep track of all screws as they are small and very easy to lose
  2. At this point most of the parts in the camera should be free moving. Take note of the small free moving flap near the battery port seen in the first of the three photos. Now pry apart the top and bottom shell of the case.
    • At this point most of the parts in the camera should be free moving.
    • Take note of the small free moving flap near the battery port seen in the first of the three photos.
    • Now pry apart the top and bottom shell of the case.
  3. Remove the two ribbon cables holding the LCD screen in place. Pull them directly out of the port they are plugged into. Take care not to tear these ribbons as they are the communication network that your screen uses to operate. Now that your LCD screen is detached you can pull it apart from the rest of the camera.
    • Remove the two ribbon cables holding the LCD screen in place. Pull them directly out of the port they are plugged into.
    • Take care not to tear these ribbons as they are the communication network that your screen uses to operate.
    • Now that your LCD screen is detached you can pull it apart from the rest of the camera.
    There’s an extra small part with some metal on it. But i cannot figure out where it came from?
    Brayan - 답글
  4. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  5. The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed. Carefully remove the inner frame lining as it can be fragile. Carefully remove the inner frame lining as it can be fragile.
    • The inner lining frame has an orange ribbon cable (circled in the image) that needs to be detached before it can be safely removed.
    • Carefully remove the inner frame lining as it can be fragile.
    There’s a really small price I cannot figure out where it came from? Can anyone help?
    Brayan - 답글
  6. After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens. After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
    • After the LCD screen has been removed there is a black metal plate that can be pulled off revealing the motherboard and the lens.
  7. To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports. To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports.
    • To separate the motherboard from the lens there are two ribbon cables that need to be pulled out of their ports.
  8. Finally to separate the motherboard from the base skeleton frame, one last silver screw and one ribbon cable need to be removed. Finally to separate the motherboard from the base skeleton frame, one last silver screw and one ribbon cable need to be removed.
    • Finally to separate the motherboard from the base skeleton frame, one last silver screw and one ribbon cable need to be removed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Scott Grambo
회원 가입일: 2015년 04월 08일
264 평판
안내서 2개 작성하였습니다
So what about the other parts not in your photos that fall ?
The bracket around the speaker and this little white part that fell out as soon as I lifted the back cover a little? can you please give more info
Kat - 답글
I'm also finding where was the white parts located. It seems that without this part, wx80 works well. If you found its location, please give me hint. Thanks.
Chung-Suh Ku -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 32
전체 시간: 1,449
