주요 콘텐츠로 건너뛰기
Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display
필요한 것
  1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Case: 1 단계, 이미지 1/1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 2 단계, 이미지 1/2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 2 단계, 이미지 2/2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 3 단계, 이미지 1/3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 3 단계, 이미지 2/3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 3 단계, 이미지 3/3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: 4 단계, 이미지 1/2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: 4 단계, 이미지 2/2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 5 단계, 이미지 1/2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 5 단계, 이미지 2/2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 6 단계, 이미지 1/3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 6 단계, 이미지 2/3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 6 단계, 이미지 3/3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
결론
Steve Van Hall
회원 가입일: 03/09/12
27 평판
안내서 2개 작성하였습니다
Clemson, Team 2-3, Benson Spring 2012 Clemson, Team 2-3, Benson Spring 2012 회원
CLEM-BENSON-S12S2G3
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 22
전체 시간: 1,662
