주요 콘텐츠로 건너뛰기
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
필요한 것
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: 1 단계, 이미지 1개 중 1개
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 2 단계, 이미지 2개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 2 단계, 이미지 2개 중 2개
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 3 단계, 이미지 1개 중 1개
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 4 단계, 이미지 2개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 4 단계, 이미지 2개 중 2개
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 5 단계, 이미지 2개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 5 단계, 이미지 2개 중 2개
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 6 단계, 이미지 1개 중 1개
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 7 단계, 이미지 2개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 7 단계, 이미지 2개 중 2개
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 8 단계, 이미지 2개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 8 단계, 이미지 2개 중 2개
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 9 단계, 이미지 3개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 9 단계, 이미지 3개 중 2개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 9 단계, 이미지 3개 중 3개
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 10 단계, 이미지 3개 중 1개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 10 단계, 이미지 3개 중 2개 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 10 단계, 이미지 3개 중 3개
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Christine Becker
회원 가입일: 10/28/13
101 평판
안내서 1개를 작성함
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 회원
UMAINE-DIAZ-F13S1G13
3 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 20
전체 시간: 3,932
