주요 콘텐츠로 건너뛰기
Disassembling Sony Ericsson W580i Back Cover
필요한 것
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: 1 단계, 이미지 1/3 Disassembling Sony Ericsson W580i Back Cover, Battery: 1 단계, 이미지 2/3 Disassembling Sony Ericsson W580i Back Cover, Battery: 1 단계, 이미지 3/3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: 2 단계, 이미지 1/1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: 3 단계, 이미지 1/1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: 4 단계, 이미지 1/3 Disassembling Sony Ericsson W580i Back Cover: 4 단계, 이미지 2/3 Disassembling Sony Ericsson W580i Back Cover: 4 단계, 이미지 3/3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Cherie
회원 가입일: 10/09/11
220 평판
안내서 2개 작성하였습니다
Cal Poly, Team 5-31, Amido Fall 2011 Cal Poly, Team 5-31, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G31
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 25
전체 시간: 8,726
