주요 콘텐츠로 건너뛰기
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
필요한 것
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: 1 단계, 이미지 1/1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 2 단계, 이미지 1/1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 3 단계, 이미지 1/1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 4 단계, 이미지 1/1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 5 단계, 이미지 1/1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 6 단계, 이미지 1/1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 7 단계, 이미지 1/1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Artem Nikulkov
회원 가입일: 10/22/10
313 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 9
전체 시간: 21,090
