이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
- Remove battery.
- Remove memory tray door (1 Screw).
- Remove hard drive door (1 Screw).
- Remove hard drive (3 Screws).
- Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
- Remove CD/DVD Drive by sliding it out.
- Remove three more screws, which were hiding under the DVD drive.
- Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
- The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
- Fire up the air compressor and blow out dust from the fan and heatsinks.
- If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
다른 8명이 해당 안내서를 완성하였습니다.
