주요 콘텐츠로 건너뛰기
Disassembling Soundmates V2 Case
필요한 것
  1. Disassembling Soundmates V2 Case, Soundmates V2 Case: 1 단계, 이미지 2개 중 1개 Disassembling Soundmates V2 Case, Soundmates V2 Case: 1 단계, 이미지 2개 중 2개
    • Flip open the cover and insert a thin flathead screwdriver in the seam by the hinge
    • Rotate the screwdriver just enough to create a gap between the two halves of the case
    • If this doesn't work very well, try the other side
    • Insert a spudger or another flathead bit into the new gap
    • This may cause some cosmetic damage
  2. Disassembling Soundmates V2 Case: 2 단계, 이미지 3개 중 1개 Disassembling Soundmates V2 Case: 2 단계, 이미지 3개 중 2개 Disassembling Soundmates V2 Case: 2 단계, 이미지 3개 중 3개
    • Once you've created a small gap, the lid should come off fairly easily
    • Run the spudger around the case until the two halves separate
    • If the top half doesn't come straight up and out, it may break off the charging port, like it did with mine. Go slowly and use caution
  3. Disassembling Soundmates V2 Case: 3 단계, 이미지 1개 중 1개
    • Remove the two Philips #00 screws securing the board
  4. Disassembling Soundmates V2 Case: 4 단계, 이미지 1개 중 1개
    • Gently lift the circuitboard off. Not too high; it's still wired to the battery
    • Now just pull off the battery; it's only held down by a sticky foam pad
  5. Disassembling Soundmates V2 Case: 5 단계, 이미지 1개 중 1개
    • Done! Hope you didn't break anything like I did.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
darth mango
회원 가입일: 03/13/23
3,487 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 42
전체 시간: 831
