주요 콘텐츠로 건너뛰기
Disassembling Speak And Spell Case
필요한 것
  1. Disassembling Speak And Spell Case, Case: 1 단계, 이미지 2개 중 1개 Disassembling Speak And Spell Case, Case: 1 단계, 이미지 2개 중 2개
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: 2 단계, 이미지 1개 중 1개
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
bushing
회원 가입일: 04/23/10
10,463 평판
안내서 13개를 작성함
1가이드 댓글
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 5,367
