주요 콘텐츠로 건너뛰기
Disassembling TDK Life on Record bottom panel
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
  1. Disassembling TDK Life on Record bottom panel, Disassembling TDK Life on Record bottom panel: 1 단계, 이미지 1개 중 1개
    • Remove the four rubber feet of the device using a metal spudger.
  2. Disassembling TDK Life on Record bottom panel: 2 단계, 이미지 2개 중 1개 Disassembling TDK Life on Record bottom panel: 2 단계, 이미지 2개 중 2개
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. Disassembling TDK Life on Record bottom panel: 3 단계, 이미지 2개 중 1개 Disassembling TDK Life on Record bottom panel: 3 단계, 이미지 2개 중 2개
    • Pull the bottom cover of the device towards you.
  4. Disassembling TDK Life on Record bottom panel: 4 단계, 이미지 2개 중 1개 Disassembling TDK Life on Record bottom panel: 4 단계, 이미지 2개 중 2개
    • Remove the four 13 mm Phillips #1 screws.
  5. Disassembling TDK Life on Record bottom panel: 5 단계, 이미지 2개 중 1개 Disassembling TDK Life on Record bottom panel: 5 단계, 이미지 2개 중 2개
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. Disassembling TDK Life on Record bottom panel: 6 단계, 이미지 1개 중 1개
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
결론
작성자
3다른 기여자 명과 함께
Eduardo Barrios
회원 가입일: 09/14/15
359 평판
안내서 2개를 작성함
CSU Fullerton, Team 1-2, Bruce Fall 2015 CSU Fullerton, Team 1-2, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G2
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 75
