주요 콘텐츠로 건너뛰기
Disassembling the Teac DC-D2831
필요한 것
  1. Disassembling the Teac DC-D2831, Disassembling the Teac DC-D2831: 1 단계, 이미지 1/1
    • Make sure the device is turned off and unplugged. This will eliminate the danger of getting electrocuted while repairing the device or damaging components.
  2. Disassembling the Teac DC-D2831: 2 단계, 이미지 1/2 Disassembling the Teac DC-D2831: 2 단계, 이미지 2/2
    • Lift the lid to get to the turntable.
    • Using the appropriate tools (needle-nose pliers, tweezers, screwdriver, etc.), remove the snap ring from the center of the turntable. The snap-ring is the small metal ring around the axel of the turntable.
    • The snap-ring is hard to remove so be patient and don't be afraid to use some force.
    • Feel free to use whatever tool(s) that will remove the snap-ring. The above list of tools are just a suggestions.
  3. Disassembling the Teac DC-D2831: 3 단계, 이미지 1/2 Disassembling the Teac DC-D2831: 3 단계, 이미지 2/2
    • Gently lift the turntable from the rest of the device.
    • If the device has a faulty belt, see the belt repair guide here: Belt Repair Guide
  4. Disassembling the Teac DC-D2831: 4 단계, 이미지 1/1
    • Remove the screws on the side of the device using a Phillips #2 screwdriver.
    • When removing the screws, take note of which screws go where.
    • 27.0mm
    • 19.8mm
    • 12.0mm
  5. Disassembling the Teac DC-D2831: 5 단계, 이미지 1/2 Disassembling the Teac DC-D2831: 5 단계, 이미지 2/2
    • Lift the base that the turntable was resting on from the rest of the device.
    • Remove the base slowly so to not sever the connection with the wire attached from the base to the circuit board.
  6. Disassembling the Teac DC-D2831: 6 단계, 이미지 1/1
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jake Hamilton
회원 가입일: 09/19/12
167 평판
안내서 2개 작성하였습니다
Cal Poly, Team 2-61, Propen Fall 2012 Cal Poly, Team 2-61, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G61
4 회원들
안내서 5개 작성하였습니다
댓글 2개
How to remove lid from CD-D2831
jfranklinhamm - 답글
So radio sound and tape work and sound is great. However when turn table is on the sound is low only on that component any help would be greatly appreciated
Joanna Chavez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 4,665
