주요 콘텐츠로 건너뛰기
Disassembling TomTom One XL Back Panel
필요한 것
  1. Disassembling TomTom One XL Back Panel, Back Panel: 1 단계, 이미지 1/2 Disassembling TomTom One XL Back Panel, Back Panel: 1 단계, 이미지 2/2
    • Remove the 4 .4mm screws on the back of the device.
  2. Disassembling TomTom One XL Back Panel: 2 단계, 이미지 1/1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. Disassembling TomTom One XL Back Panel: 3 단계, 이미지 1/1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. Disassembling TomTom One XL Back Panel: 4 단계, 이미지 1/2 Disassembling TomTom One XL Back Panel: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
결론
DeVhan
회원 가입일: 03/11/15
401 평판
안내서 4개 작성하였습니다
Colorado Springs, Team 9-6, Panko Spring 2015 Colorado Springs, Team 9-6, Panko Spring 2015 회원
UCCS-PANKO-S15S9G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 450
