소개
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
필요한 것
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
