주요 콘텐츠로 건너뛰기
Disassembling Toshiba A1304T Front Cover
필요한 것
  1. Disassembling Toshiba A1304T Front Cover, Front Cover: 1 단계, 이미지 1/1
    • Open the phone so that it matches the photos to the left.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located around the main LCD screen.
  2. Disassembling Toshiba A1304T Front Cover: 2 단계, 이미지 1/2 Disassembling Toshiba A1304T Front Cover: 2 단계, 이미지 2/2
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Disassembling Toshiba A1304T Front Cover: 3 단계, 이미지 1/2 Disassembling Toshiba A1304T Front Cover: 3 단계, 이미지 2/2
    • Insert the head of a flathead screwdriver into the seam between the front cover and the phone.
    • Pry gently until the cover gives slightly to create a slightly wider opening. You may hear a distinct pop as you pry.
    • Remove the screwdriver and re-insert it into another portion of the seam. Continue making gaps around the cover of the phone until it is completely detached from the body.
결론
Christopher
회원 가입일: 04/22/10
90 평판
안내서 8개 작성하였습니다
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 회원
CPSU-MANESS-S10S16G6
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 16
전체 시간: 2,123
